Specify work product and document location references
P6 Professional supports two types of document location references, private and public. Private location references can only be viewed by P6 Professional users. Public location references can be viewed by all project participants. For this reason, public location references typically refer to files stored in a widely accessible network location such as an intranet or the Internet.
- Choose Project, Work Products and Documents, then select the work product or document.
- Display WP & Doc Details, then click the Files tab.
- In the appropriate location field, type the full path and filename of the document.
Tip
- Click the Browse button to select a file.
Related Topics
Display work product and document details in the WPs and Docs window
Last Published Wednesday, April 10, 2024
