Tracking and analyzing budgets
The resource spreadsheet enables you to see an overall picture of unit and cost budget distributions, and the variance amounts resulting from current use versus original estimates at the activity level.
For high-level budgeting information, display the Projects Window (choose Enterprise, Projects) and then select Original Budget and Current Variance as columns.
You can also use the preformatted reports to track budget amounts at the project and activity level.
Related Topics
The Resource Usage Spreadsheet
Last Published Tuesday, March 4, 2025
