Assign activity codes and values to activities
- Choose Project, Activities, then select the activity to which you want to assign a code and value.
- Display Activity Details, then click the Codes tab.
- Click Assign.
- If an applicable activity code value does not exist, then proceed as follows to create one. Otherwise, go to the next step.
Click the New icon
, type the new value and its description, and click OK. Then go to the next step to select and assign it to the selected activity. - Select the activity code value you want to assign.
You can only assign one value per code. - Click Assign, then click Close.
Notes
- If you intend to use reporting software, avoid using commas when creating data other than Project names. The way that data is passed to some reporting software can cause a comma to be interpreted as a delimiter between data items.
- You can assign global activity codes to any activity. You can only assign project level activity codes to activities in the project where the codes were created.
- You can only assign EPS-level activity codes that have been assigned to the selected activity's project.
- Any EPS-level activity code associated with an inaccessible EPS node will appear under the "No EPS ID" node in the Assign Activity Codes dialog box.
- The New icon
is disabled if no code band is selected or if you do not have security to edit the selected type of activity code (global, EPS, or project).
Related Topics
Last Published Tuesday, March 4, 2025
