Define columns for a tracking layout
For layout elements displayed in column format, you can specify the columns you want to include.
- In the Top Layout window, click the Display Options bar and choose Top Layout Options, Columns. In the Bottom Layout window, right-click in the table and choose Columns.
- Choose one of the following options.
Default: Displays the standard columns for the current layout type.
Cost: Displays cost-related columns for the current layout type.
OBS: Displays OBS-related columns for the current layout type.
Customize: Displays the Columns dialog box so you can select the columns to include in the layout. - If you choose Customize, under Available Options select the column you want to add and click
To add all available columns, click
To remove columns, under Selected Options select the column you want to remove and click
To remove all columns, click
To change the order in which the columns are displayed, under Selected Options select the column you want to move and click
or
to change the column's position.
To use the default column display, click Default.
To preview the selected columns without closing this dialog box, click Apply. - To change a column title, width, or heading alignment, click Edit Column.
Type a new title and width, select an alignment option, then click OK. - When you are finished defining layout columns, click OK.
Tip
- The Summary columns category contains several columns that you can include to identify layouts that display summarized data and identify when data were last summarized.
Last Published Tuesday, March 4, 2025
