Using Work Planning for P6 EPPM Data
Primavera Analytics supports Work Planning for P6 EPPM data. Work Planning is a method of tracking how work is progressing based on a set of user-determined points in time. Similar to Burn Down, Work Planning also uses project-level user-defined fields (UDFs) to select the P6 EPPM projects included in the Work Planning calculations and metrics and also the point in time you want to use for the comparison.
Related Topics
Creating Project UDFs for Work Planning Subject Areas
Selecting a Project for the Work Planning Subject Area
Scheduling a Work Planning Project
Last Published Tuesday, January 7, 2025
