Enabling P6 EPPM Projects for Real-Time Analytics
Oracle Data Integrator (ODI) provides support for real-time analytics, which enables project changes to be immediately sent over to the Primavera Data Warehouse instead of waiting for the next scheduled ETL. Once a project is selected for real-time analytics, it is no longer part of the scheduled ETL.
Note: Primavera Unifier projects cannot be enabled for real-time analytics.
To enable a P6 EPPM project for real-time analytics, complete the following steps:
- Sign in to P6 EPPM.
- Click the Projects tab.
- Click the EPS page.
- Locate the project you want to enable for real-time analytics.
- Click the gear icon
to expand the menu, and select Set Project Preferences. - In the Project Preferences window, click the Analytics & Services tab.
- In the Analytics section, expand the Data Warehouse Update Frequency (ODI Only) drop-down menu and change the setting to Immediate.
- Click OK to save the project preferences.
Repeat these steps as needed to enable for real-time analytics for other P6 EPPM projects.
Last Published Tuesday, January 7, 2025
