Keyboard Shortcuts
KeYou can use your keyboard to navigate throughout Primavera Analytics and the Analytics Administration application, and access frequently used or important functionality. Use the Tab key to cycle through elements within the application, and press Enter or Spacebar to access them. Some keyboard shortcuts may change depending on the browser you use.
Common Shortcuts
The following shortcuts are common to all pages of Primavera Analytics:
- Press Tab to navigate to any element.
- Press Enter to click on the element.
- Press the space bar to select a check box.
- Press Shift+Tab to navigate back to any element.
- Use the Arrow keys(LEFT and RIGHT) to select radio buttons/within the table row.
- Use Arrow keys(UP and DOWN) to move through the drop-down lists/ to select values in combo boxes.
Related Topics
Title and Copyright Information
Last Published Tuesday, January 7, 2025
