Setting Up JBoss EAP Docker
This Dockerfile extends the JBOSS EAP domain.
The docker related files are located in the folder docker_scripts/jboss in release.
Prerequisites
The services or components that should be available before the docker installation are as follows:
  • Docker should be installed, preferred version: 19.03.11-ol
  • The required packages and artifacts should be placed in a host directory <IBSS base dir>.
  • For the table management configuration windows network shared location needs to be mounted in a host directory <mount dir>.
  • In order to pull images from Oracle Container Registry, you need to register and log in to the Oracle Container registry.
docker login container-registry.oracle.com
Docker Login
