Microsoft Edge Options
Enable IE mode on Microsoft Edge
There are multiple ways to enable IE, follow anyone of the methods to enable IE.
Method 1
To enable the IE mode, follow the below steps:
- Open Microsoft Edge.
- Click Settings and More (ellipsis) button on the top-right corner.
- Select the Settings option.
- Click Default browser.
- Under the Internet Explorer compatibility section, turn on the Allow sites to be reloaded in Internet Explorer mode toggle switch.
- Click the Restart button.
Method 2
If you are on a device managed by your organization you will NOT see the option to Allow sites to be reloaded in Internet Explorer under edge://settings/defaultbrowser to allow Internet Explorer mode through the More tools menu.
Follow the below steps for configuring IE mode policies:
- Install the latest version of Microsoft Edge.
- Enterprise Mode Site List Manger -SiteList.
- Download the Enterprise Mode Site List Manger v2 from https://www.microsoft.com/en-us/download/details.aspx?id=49974
- Create a SiteList xml as below:
- Open the Enterprise Mode Site List Manger, click Add and type the rm url (ex: fsgbu-mum-603.snbomprshared1.gbucdsint02bom.oraclevcn.com/rm)
- Under Compat Mode select IE7 Document Mode.
- Under Open in select IE11 - >Save
- Click File -> Save to XML to save the file as SiteList.xml on your PC(ex: C:\SiteList.xml)
- Edge group policy template
- Download the Edge Chromium group policy template files from https://www.microsoftedgeinsider.com/de-de/enterprise
- For adml, open the .zip file and go to policy_templates -> windows -> admx ->en-US
- Copy all the *.adml files to C:\Windows\PolicyDefinitions\en-US
- For admx, go to policy_templates > windows > admx>
- Copy msedge.admx to C:\Windows\PolicyDefinitions\
- Group Policy Editor
- Open the Local Group Policy Editor [from run gpedit.msc ]
- Computer Configuration -> Administrative Templates ->Microsoft Edge
- Microsoft Edge -> Configure Internet Explorer integration -> Edit.
- Change to Enabled and select Internet Explorer Mode -> Apply.
- Microsoft Edge -> Configure the Enterprise Mode Site List -> Edit.
- Change to Enabled and set the path to the SiteList.xml path (File saved in Step #2, last point C:\SiteList.xml) .
- Apply the above changes:
- Go to browser, edge://policy/
- Reload Policies
- Open the Edge browser, and navigate to the above added url (ex: fsgbu-mum-603.snbomprshared1.gbucdsint02bom.oraclevcn.com/rm).
- Try restarting the machine once to apply the changes if step 6 is not working.
