Oracle Software Delivery Cloud
Prior to installation, please ensure that the source machine(s) where Insbridge will be loaded has an unzip utility. An unzip utility for most platforms is available on the Oracle Software Delivery Cloud download page.
Files are downloaded with part numbers as file names. Please make note of the part numbers you have downloaded and the corresponding file name. You may be asked to provide the part numbers or the file name if you contact Oracle Support.
The installation downloads you can select are:
  • Insbridge - Windows – Required for all RateManager installations. The Insbridge installation is for a 64-bit system
  • Insbridge - WebSphere - eng – Required if you are using WebSphere
  • Insbridge - WebLogic - eng – Required if you are using WebLogic
  • Insbridge - JBoss - eng - Required if you are using JBoss.
  • Insbridge - TomEE - eng – Required if you are using TomEE
The Insbridge - Windows folder contents:
  • Databases
    • SQL Server
    • 2016, 2017, 2019
    • RateManager – IBRM
      • Latin1_General_BIN
        • DATABASE_BACKUP_IBRM_TEMPLATE_CASE_SENSITIVE.bak
      • SQL_Latin1_General_CP1_CI_AS
        • DATABASE_BACKUP_IBRM_TEMPLATE.bak
    • Security – IB_CLIENT
        • DATABASE_BACKUP_IB_CLIENT_TEMPLATE.bak
    • SoftRater – IBSR
        • DATABASE_BACKUP_IBSR_TEMPLATE_CASE_SENSITIVE.bak
        • DATABASE_BACKUP_IBSR_TEMPLATE.bak
    • Oracle BI Publisher
      • OBI_PUBLISHER.exe
    • Oracle Client
      • ODAC12.1.0.2.4Xcopy_x64.zip
    • Oracle Insurance Insbridge Enterprise Rating (x64).exe
    Run the installation file and create the IB_CLIENT database for any new installation.
    The other folders and files may not be needed, depending upon the kind of setup you want. Everything for a Windows only installation is in the 5.6.4-Insbridge-windows folder. If you want to incorporate a Java environment, please download the corresponding SoftRater file. SoftRater downloads are not required if you are running in Windows only.
    Microsoft Edge
    Access IBSS and IBFA via web browser. Ensure that you are using Microsoft Edge Version 110.0.1587.63 or above.
    1. Install the latest version of Microsoft Edge.
    2. Enterprise Mode Site List Manger - SiteList
      • Download the Enterprise Mode Site List Manger v2 from https://www.microsoft.com/en-us/download/details.aspx?id=49974
      • Create a SiteList xml as given below:
        • Open the Enterprise Mode Site List Manger, click Add and type the rm url (ex: fsgbu-mum-603.snbomprshared1.gbucdsint02bom.oraclevcn.com/rm)
        • In the Compat Mode select IE7 Document Mode
        • Under Open in select IE11 and click Save
        • Click File and then Save to XML to save the file as SiteList.xml on your PC(ex: C:\SiteList.xml)
    3. Edge group policy template
      • Download the Edge Chromium group policy template files from https://www.microsoftedgeinsider.com/de-de/enterprise
      • For adml, open the .zip file and go to policy_templates > windows > admx > en-US
      • Copy all the *.adml files to C:\Windows\PolicyDefinitions\en-US
      • For admx, go to policy_templates > windows > admx >
      • Copy msedge.admx to C:\Windows\PolicyDefinitions\
    4. Group Policy Editor
      • Open the Local Group Policy Editor [from run gpedit.msc ]
      • Go to Computer Configuration > Administrative Templates > Microsoft Edge > Configure Internet Explorer integration > Edit
      • Change to Enabled and select the Internet Explorer Mode and click Apply
      • Microsoft Edge > Configure the Enterprise Mode Site List > Edit
      • Change to Enabled and set the path to the SiteList.xml path (File saved in Step 2 , last point C:\SiteList.xml) .
    5. Apply the above changes
      • Go to the browser, edge://policy/ and Reload Policies
    6. Open the Edge browser, and navigate to the above added url (ex: <Your_Server_Name>/rm),
    7. Try restarting the machine to apply the changes if Step 6 is not working.
