TomEE Server Configurations for IBSS
TomEE Installation
- Download Apache TOMEE 9.1.2 Plume from https://tomee.apache.org/download.html
- Extract the zip file.
JAVA 17
- Check the version of installed JDK before installing TomEE 9.1.2.
- Open command prompt and type SET JAVA_HOME
- Make sure that the JAVA_HOME is set to JAVA 17.
IBSS Config File Path Configurations
- Go to Apache TomEE installation folder\conf
- Open the file catalina.properties to edit
- Add the below lines at the end of the file:
INSBRIDGE_INSTANCE_APP_DIR=c:/insbridge/logs
INSBRIDGE_APP_DIR=c:/insbridge
log_dir=c:/insbridge/logs/logs
insbridge.net.softraterconfig.xml file
- Change the engine_type=”tomee”
- Should look like below, this is a one time change:
<softrater datelastmod="2020-03-12 03:08:47 PM" engine_type="tomee" format_version="3.0" softdata_version="SoftData Version 1" version="SoftRater Version 3">
System.properties Configurations
- Open system.properties in the Tomee/conf folder.
- Add openejb.classloader.forced-load=com.oracle to load com.oracle packages.
- Comment tomee.serialization.class and add the next entry for listing.
Note: TomEE does not load the package with name "Oracle" in it, Ex: com.oracle.ins.ru.sr.ejb.esi
#tomee.serialization.class.blacklist = *
tomee.serialization.class.whitelist = *
Catalina.properties Configuration
- Go to Apache Tomee installation folder\conf\catalina.properties
- Add openejb to the jars to skip list in catalina.properties
- Under "tomcat.util.scan.StandardJarScanFilter.jarsToSkip" there will be list of jar names to be skipped during startup, here add jakartaee-*.jar,\ openejb-*.jar,\ as below:
Update the Jars in TomEE Lib
Make sure the jars are in place before starting the TomEE Server.
Remove all jars starting with "CXF"
Navigate to <TomEE_Home>\lib.
Remove the following jars that start with "cxf-"
(A total of 20 jars related to Apache CXF)
Remove default Email Library Reference from Lib
- Navigate to <TomEE_Home>\lib.
- Remove the following two jars from the lib directory.
Download IBSS WAR
Download IBSS.war build from pre informed directory.
Deploy IBSS To TOMEE
- Stop the TomEE server if running.
- Delete the IBSS.war and IBSS folder under \webapps directory in Tomee Installation Folder.
- Copy the new WAR to the \webapps folder in TomEE installation folder.
- Start the TomEE server tomee\bin\startup.bat.
- The WAR will be extracted to the IBSS Folder under webapps
- IBSS can be accessed from the URL: http://localhost:8080/IBSS/index.jsp
