IBSS - Configure RM Portal Login
To configure RM portal login, follow these steps:
- Open the insbridge.net.softraterconfig.xml file
- Find the security section at the bottom of the file.
- Add new attribute portal="disabled".
- Save the file.
- Restart the IBSS Application Server.
<security csrf_protection="disabled" password="159754A9@WBP6X$SC9" portal="disabled" type="None" username="2S29]$Z4*O"/></softrater>
Go to IBSS -> config -> Security.
Select Rate Manager Portal and click Save.
Refresh the IBSS URL. You should be redirected to the Portal Login Error page.
Any change in security screen requires a complete Application server restart to take effect. It applies for both enabling and disabling any of the security type availAble in IBSS.
