FundLevels Element
The FundLevels transaction element provides a set of conditions that identify the child funds' or lateral funds' relationship to parent funds. This is relevant to Activities because Allocations must identify Parent level funds and trading (movement of money as investments or withdrawals) must identify specific Child or Lateral fund levels. Definition of this relationship is required in any Activity that trades units into and out of funds that have these child and lateral funds, otherwise, there is no impact.
| Element | Parent Element | Attribute | Definition |
| <FundLevels> | <Transaction> | Optional: This element is a structure to define the relationships between fund levels. This pertains to unit based funds only and is ignored for other funds. |
<FundLevel>
<FundLevels> |
Required, Repeatable: This element identifies the fund level that is being defined. |
LEVEL |
Required This attribute identifies the fund level to be used by money movement. Values:
<Relation> |
<FundLevel> |
Optional This section contains the instructions to relate the parent funds in allocations to the actual funds used in assignments. Multiple relations may be necessary to identify the single child or lateral fund. This element is required when the LEVEL attribute is Child or Lateral. This element is ignored when the LEVEL attribute is Parent. |
<Criteria>
<Relation> |
Required, Repeatable: Each <Criteria> establishes a single relationship for Child and Lateral fund discovery. The value of this element is compared to a Fund's field to determine which of multiple related child funds to add or remove money. The element's value will often identify a Policy or Segment Field. Values:
| <Criteria> |
NAME |
Required: The attribute provides the Fund's field name used in the match to establish a relationship. Values:
| <Criteria> |
DATATYPE |
Required: The attribute provides the data type of the fund field and Policy field. Values:
XML Schema
<Transaction>
<FundLevels>
<FundLevel LEVEL="{Parent | Child | Lateral]">
<Relation>
<Criteria NAME="[field name]" DATATYPE="[TEXT | DATE | INTEGER | DECIMAL]">[variable name]</Criteria>
<Criteria>...</Criteria>
</Relation>
</FundLevel>
<FundLevel>...</FundLevel>
</FundLevels>
</Transaction>
XML Example
<Transaction>
<FundLevels>
<FundLevel LEVEL="Child">
<Relation>
<Criteria NAME="BandVariable" DATATYPE="TEXT">Policy:BandVariable</Criteria>
</Relation>
</FundLevel>
<FundLevel LEVEL="Lateral">
<Relation>
<Criteria NAME="SubClass" DATATYPE="TEXT">Policy:SubClass</Criteria>
</Relation>
</FundLevel>
</FundLevels>
</Transaction>
