Membership Element
The <Membership> element triggers the evaluation of class memberships for all participants in a Group Customer and related Group Customers or for a Policy's Primary Member client. This is applicable to a Group Customer level activity or Policy level activity. The following describes the general behavior:
  • If configured in a Group Customer level activity and a ClientGUID is provided, membership evaluation is limited to all participants of the Group Customer identified by the <ClientGUID> element.
  • If the <ClientGUID> element is not configured in a Group Customer level activity, membership evaluation is processed for all participants of the activity's Group Customer and all its related Group Customers.
  • If the element is configured in a Policy level activity, membership is evaluated for the Policy's Primary Member role and to all related Group Customers the member is associated with.
  • The results of membership may be persisted in the AsClassMembership table.
  • The results of membership will be displayed in a Membership tab in Activity Details.
MembershipElement: Elements and Attributes
Element
Parent Element
Attribute
Description
<Membership>
<Transaction>
Optional:
This element triggers Membership processing for the Activity.
<ClassGroup>
<Membership>
Required, Repeatable:
This contains the definition for evaluating membership of a Group Customer or membership of a Primary Member in its Group Customer.  An activity may contain this element multiple times for the multiple memberships various clients may have.
<ClassGroup>
TYPE
Required:
This identifies the class group type by its code value.  The definition in the parent element applies to this class group type.
Values:
  • code value from AsCodeClassGroupType
<ClassGroup>
DISPLAYMEMBERSHIPCLASS
Optional:
Indicates which class membership types to display.
Values:
  • All:
    • Displays all available Membership Classes
  • LowestOnly:
    • Displays only the leaf nodes or lowest level Membership Classes
<ClientGUID>
<ClassGroup>
Optional:
This element identifies the Group Customer by its ClientGUID for which membership will be evaluated.  If this element is not configured in a Group Customer activity, membership evaluation is processed for all participants of the activity's Group Customer and all its related Group Customers.  If the element is configured in a Policy level activity, membership is evaluated for the policy's Primary Member role and for all related Group Customers the member is associated with.
Values:
  • field
  • variable
<WriteMembership>
<ClassGroup>
Optional:
Indicates the persistence of Membership records in the database.
Values:
  • Yes
    • Default
    • Membership records are committed to the database
  • No
    • Membership records are not committed to the database
  • field
  • variable
<EffectiveFromDate>
<ClassGroup>
Optional:
Provides the effective starting date of the Membership. The value must be a valid date.
Values:
  • Activity: EffectiveDate
    • default
    • The resulting date is the activity's effective date value.
  • SystemDate
    • The resulting date is the system date value.
  • field
  • variable
<EffectiveToDate>
<ClassGroup>
Optional:
Provides the effective end date of the Membership. The value must be a valid date.
Values:
  • "12/31/9999"
    • default
    • The resulting date is the literal value.
  • SystemDate
  • field
  • variable
XML Schema
<Transaction>
    <Membership>
        <ClassGroup TYPE="[class group type]" DISPLAYMEMBERSHIPCLASS="[class membership type]">
            <ClientGUID>[field | variable]</ClientGUID>
            <WriteMembership>[Yes | No]</WriteMembership>
            <EffectiveFromDate>[system date | date field]</EffectiveFromDate>
            <EffectiveToDate>[system date | date field]</EffectiveToDate>
        </ClassGroup>
        <ClassGroup>...</ClassGroup>
    </Membership>
</Transaction>
XML Example
<Transaction>
    <Membership>
        <ClassGroup TYPE="02" DisplayMembershipClass="All">
            <ClientGUID>GroupCustomerMV</ClientGUID>
            <WriteMembership>No</WriteMembership>
            <EffectiveFromDate>Activity:EffectiveDate</EffectiveFromDate>
            <EffectiveToDate>SystemDate</EffectiveToDate>
        </ClassGroup>
    </Membership>
</Transaction>
