6.3.7.5 Exadataメトリックを使用したスマートI/Oの監視
スマートI/Oのメトリックは、objectType=SMARTIOであるMETRICCURRENT、METRICDEFINITIONおよびMETRICHISTORYオブジェクトで識別されます。
cumulativeメトリックの場合は、様々なcollectionTime期間から値を減算することにより、特定の期間のメトリック値を算出できます。
例6-6 スマートI/Oのメトリック定義の表示
この例は、Oracle Exadata System Softwareで使用可能なスマートI/Oのメトリック定義を表示する方法を示しています。
CellCLI> LIST METRICDEFINITION ATTRIBUTES NAME,DESCRIPTION WHERE OBJECTTYPE = SMARTIO
SIO_IO_EL_OF "Cumulative number of megabytes eligible for smart IO offload"
SIO_IO_EL_OF_SEC "Number of megabytes per second eligible for smart IO offload"
SIO_IO_OF_RE "Cumulative number of interconnect megabytes returned by smart IO"
SIO_IO_OF_RE_SEC "Number of interconnect megabytes per second returned by smart IO"
SIO_IO_PA_TH "Cumulative number of megabytes of passthru IOs by smart IO"
SIO_IO_PA_TH_SEC "Number of megabytes per second of passthru IOs by smart IO"
SIO_IO_RD_FC "Cumulative number of megabytes read from flash cache by smart IO"
SIO_IO_RD_FC_HD "Cumulative number of megabytes read from both flash cache and hard disk by smart IO"
SIO_IO_RD_FC_HD_SEC "Number of megabytes per second read from both flash cache and hard disk by smart IO"
SIO_IO_RD_FC_SEC "Number of megabytes per second read from flash cache by smart IO"
SIO_IO_RD_HD "Cumulative number of megabytes read from hard disk by smart IO"
SIO_IO_RD_HD_SEC "Number of megabytes per second read from hard disk by smart IO"
SIO_IO_RD_RQ_FC "Cumulative number of read IO requests from flash cache by smart IO"
SIO_IO_RD_RQ_FC_HD "Cumulative number of read IO requests from both flash cache and hard disk by smart IO"
SIO_IO_RD_RQ_FC_HD_SEC "Number of read IO requests per second from both flash cache and hard disk by smart IO"
SIO_IO_RD_RQ_FC_SEC "Number of read IO requests per second from flash cache by smart IO"
SIO_IO_RD_RQ_HD "Cumulative number of read IO requests from hard disk by smart IO"
SIO_IO_RD_RQ_HD_SEC "Number of read IO requests per second from hard disk by smart IO"
SIO_IO_RV_OF "Cumulative number of megabytes sent to DB node to balance CPU by smart IO"
SIO_IO_RV_OF_SEC "Number of megabytes per second sent to DB node to balance CPU by smart IO"
SIO_IO_SI_SV "Cumulative number of megabytes saved by storage index"
SIO_IO_SI_SV_SEC "Number of megabytes per second saved by storage index"
SIO_IO_WR_FC "Cumulative number of megabytes of flash cache population writes by smart IO"
SIO_IO_WR_FC_SEC "Number of megabytes per second of flash cache population writes by smart IO"
SIO_IO_WR_HD "Cumulative number of megabytes written to hard disk by smart IO"
SIO_IO_WR_HD_SEC "Number of megabytes per second written to hard disk by smart IO"
SIO_IO_WR_RQ_FC "Cumulative number of IO requests for flash cache population writes by smart IO"
SIO_IO_WR_RQ_FC_SEC "Number of IO requests per second for flash cache population writes by smart IO"
SIO_IO_WR_RQ_HD "Cumulative number of write IO requests to hard disk by smart IO"
SIO_IO_WR_RQ_HD_SEC "Number of write IO requests per second to hard disk by smart IO"
列キャッシュ・メトリックは、name like 'FC_COL.*'を持つものとして識別されます
例6-7 列キャッシュのメトリック定義の表示
この例は、Oracle Exadata System Softwareで使用可能な列キャッシュのメトリック定義を表示する方法を示しています。
CellCLI> LIST METRICDEFINITION ATTRIBUTES NAME,DESCRIPTION WHERE NAME LIKE 'FC_COL.*'
FC_COL_BYKEEP_USED "Number of megabytes used for keep objects in Columnar FlashCache"
FC_COL_BY_USED "Number of megabytes used in Columnar FlashCache"
FC_COL_IO_BYKEEP_R "Number of megabytes read from Columnar FlashCache for keep objects"
FC_COL_IO_BYKEEP_R_SEC "Number of megabytes read per second from Columnar FlashCache for keep objects"
FC_COL_IO_BY_R "Number of megabytes that were read from Columnar FlashCache"
FC_COL_IO_BY_R_ELIGIBLE "Number of megabytes eligible to read from Columnar FlashCache"
FC_COL_IO_BY_R_ELIGIBLE_SEC "Number of megabytes per second eligible to read from Columnar FlashCache"
FC_COL_IO_BY_R_SEC "Number of megabytes per second that were read from Columnar FlashCache"
FC_COL_IO_BY_SAVED "Number of megabytes saved by reads from Columnar FlashCache"
FC_COL_IO_BY_SAVED_SEC "Number of megabytes saved per second by reads from Columnar FlashCache"
FC_COL_IO_BY_W_POPULATE "Number of megabytes that are population writes into Columnar FlashCache due to read miss"
FC_COL_IO_BY_W_POPULATE_SEC "Number of megabytes per second that are population writes into Columnar FlashCache due to read miss"
FC_COL_IO_RQKEEP_R "Number of requests read for keep objects from Columnar FlashCache"
FC_COL_IO_RQKEEP_R_SEC "Number of requests read per second for keep objects from Columnar FlashCache"
FC_COL_IO_RQ_R "Number of requests that were read from Columnar FlashCache"
FC_COL_IO_RQ_R_ELIGIBLE "Number of reads eligible for Columnar FlashCache"
FC_COL_IO_RQ_R_ELIGIBLE_SEC "Number of reads per second eligible for Columnar FlashCache"
FC_COL_IO_RQ_R_SEC "Number of requests per second that were read from Columnar FlashCache"
FC_COL_IO_RQ_W_POPULATE "Number of requests that are population writes into Columnar FlashCache due to read miss"
FC_COL_IO_RQ_W_POPULATE_SEC "Number of requests per second that are population writes into Columnar FlashCache due to read miss"
親トピック: スマートI/Oの監視
