10. ACH Debit Receipts - Reversal Processing
10.1 Upload of Pacs.007 Message
If the ACH Debit payment is reversed by the Creditor bank, pacs.007.001.09 message is received by the Debtor bank with the reversal details.
10.1.1 Pacs.007 Message upload
File level Validations
The message is to be placed in a specified folder and the file path and Network details are to be sent in file envelope service. The file type to be used is 'ACHDDReversal'.
On upload of the message pacs.007.001.09, system performs the below validations:
l File format validations - This is done based on the XSD maintained in the 'Schema Definition File Path' for the file type 'ACHDDReversal' in File Parameters Detailed screen PMDFLPRM.
l Validation of Number of transactions and control sum in the file, if available
Branch & Network Derivation
The below details are derived from the file envelope details available for the message:
l Host Code
l Transaction Branch
l Network Code
l Source Code
The settlement date received is the Instruction Date for the Reversal transaction. If this date falls on a Network Holiday, the Instruction Date is moved forward to next Network working Day. If Instruction Date is a back date, it is moved to current date provided current date is a Network working day. If it is Network holiday, instruction date is moved to next network working day.
Activation Date is same as the Instruction Date provided it is not a branch holiday. If it is a branch holiday, it is moved to next branch working date.
Note
Instruction Date once derived is not changed during transaction processing unless a new date is returned by External FX system.
Receipt Accounting
If the parsing & upload of the inbound pacs.007 is completed, Receipt accounting is posted if Receipt Accounting Code is maintained for ACH Debit Receipts Preferences PZDINPRF - Reversal Preferences tab.
Reversal Accounting
Event
Dr/Cr
Account
Account Type
Amount Tag
DD Receipts - Reversal
ZWRC
Dr
Nostro Account
Account
RVL_STTL_AMT
ZWRC
Cr
Network Clearing GL
GL
RVL_STTL_AMT
The return amount received in FItoFTPmtRvsl /TxInf / RvsdIntrBkSttlmAmt is consolidated for accounting. The transaction records are grouped based on Branch, Currency and settlement date.
10.1.2 Reversal Processing
If the Original transaction is in 'In Progress', 'Exception' or 'Future Valued' status, the cancellation of the original transaction is initiated once the matching and business override validations of reversal transaction are completed.
If the original transaction is already in processed status, the reversal transaction is moved to ACH Reversal Response Queue to initiate Accept/Return actions.
The following processing steps are applicable, when pacs.007 message is received for a settled ACH Debit Receipt:
l Matching with the original transaction
l Secondary fields Matching
l Reversal Days/Reason Code validation
l Sanctions screening
l Moving to Reversal Response Queue
On acceptance of the Reversal
l Sanctions screening based on Retry days
l FX rate fetch
l ECA Check
l Reversal Accounting
l Notification/IR XML generation
On return of the Reversal
l Sanctions screening based on retry days
l Return pacs.004 generation
10.1.3 ACH Reversal Response Queue
If the Original transaction is in 'Processed' status and the sanction screening of Reversal transaction is completed, it is moved to Reversal Response queue (Function ID: PQSACHRS). The Original Transaction Status is changed as 'Reversal Requested'. Reversal transaction status is 'Awaiting Response'. From Reversal Response Queue, you can manually Accept/Reject the reversal.
Queues access rights are required for the queue actions listed. Role Queue Access maintenance and User queue access maintenance screens have the new queue and actions added. Role/User level limit check is applicable for the Accept /Reject actions, if configured.
The following actions are supported:
l Accept
l Return
Both the actions require authorization. you can Delete or Reject the unauthorized actions.
10.1.3.1 Processing Accept of Reversals
On authorization of Accept action, following is the processing:
l Sanction screening
l FX Rate Fetch
l ECA check
Reversal accounting is passed with reference as reversal transaction reference:
Event
Dr/Cr
Account
Account Type
Amount Tag
ZWDR
Dr
Network Clearing GL
GL
Reversal Amount
ZWDR
Cr
Intermediary GL
GL
Reversal Amount
ZWCR
Dr
Intermediary GL
GL
Reversal Amount
ZWCR
Cr
Customer Account
Account
Reversal Amount
Accounting occurs with Reversal Reference Number.
IR/Notification generation is done on reversal acceptance processing completion.
Processing Return of Reversals
On authorization of Return action the following processing is done:
l Sanction screening: Sanctions screening based on retry days is done for the reversal transaction.
l Pacs.004 message is generated. Dispatch accounting is posted if it is configured in PMDINPRF Reversal preferences 'Return Dispatch accounting Code.
l The original transaction details in pacs.004 are populated from Reversal of ACH DD Receipts original transaction tables (the original data before any enrichment)
10.1.4 ACH Debit Receipts - Reversal Input
You can invoke ‘ACH Debit Receipts - Reversal’ screen by typing ‘PZDRVITN’ in the field at the top right corner of the Application tool bar and clicking on the adjoining arrow button.
You can specify the following fields:
Host Code
The system defaults the Host Code of transaction branch on clicking ‘New’.
Source Code
Specify the Source Code from the List of Values. All valid source codes maintained for the Host are listed.
Reversal Reference
Reversal Reference Number is system generated.
Source Reference Number
You can specify Source Reference Number.
Original Transaction Identification
Specify the Original Transaction Identification form the list of values.
All transactions of payment type 'ACH DD' are listed which are in 'Processed', 'In Progress', 'Exception' and 'Future Valued' status, if the Reversal screen is initiated as a standalone screen. If the Reversal screen is launched from the summary screen PZSIVIEW, the selected transaction identification is defaulted.
Transaction Branch
Transaction Branch is system generated.
Network Code
The system defaults the Network Code based on the Original Transaction Identification selected.
Reversal Details
Settlement Currency & Settlement Amount
These fields are defaulted as original transaction transfer currency and amount. However the amount can be modified by the user to a lesser amount, if required.
Settlement Date
Current Date is populated. You can modify the date.
Reversal Account
This field is Debit account of the original transaction. Account currency, Account branch are populated based on the Debit account.
Account Currency
Specify the Return Account Currency.
Account Branch
Specify the Account Branch.
Debit Amount
All the return codes maintained for the Network in the static table are listed.
Exchange Rate
The system defaults the Return Code Description based on the Primary Return Code selected.
FX Reference Number
Reason Code
Specify the Secondary Return Code from the list of values. All valid reason codes maintained for ACH DD in ACH Reason code maintenance (Function ID: PMDRSNCD) for the Network and Payment type 'Reversal' are listed.
Reason Code Description
The system defaults the Reason Code Description based on the Reason Code selected.
Additional Information
Specify any additional Information.
Booking Date
This field is populated as current date.
Value Date
If Original Transaction Settlement Date is not yet reached, the Reversal value date is Original Transaction Settlement Date. If the Original Transaction Settlement date is already over, the Reversal Value Date is populated as current date if it is Network working day. If the current date is not Network working day, the Value date is moved to next network working day.
Activation Date
Note
This date is rolled over only if the processing is delayed in any Exception Queue and the Return transaction is released from the queue on a later date. No holiday check is done on Return Activation Date.
Enrich
Enrich button performs date derivation. On saving a Reversal request system validates that no previous reversal request exists for the transaction in authorized or unauthorized status.
Origination Transaction Details:
The following fields are populated from ACH Debit Receipts transaction:
l Instruction Identification
l End To End Identification
l Other Details
l Interbank Settlement Date
l Inter Bank Settlement Currency
l Inter Bank Settlement Amount
l Message Identification
l Original Transaction Source Code
l Original Source Reference
10.1.4.1 ACH Debit Receipts - Reversal Summary
You can invoke ‘ACH Debit Receipts - Reversal Summary’ screen by typing ‘PZSRVITN’ in the field at the top right corner of the Application tool bar and clicking on the adjoining arrow button.
You can search using one or more of the following parameters:
l Reverse Reference
l End to End ID
l Settlement Currency
l Settlement Date
l Creditor Account Number
l Authorization Status
l Original Transaction Identification
l Network Code
l Settlement Amount
l Debtor Account Number
l Creditor Agent Member ID
Once you have specified the search parameters, click the ‘Enter Query’ button. The system displays the records that match the search criteria.
10.1.5 ACH Debit Receipts - Reversal View
You can invoke ‘ACH Debit Receipts - Reversal View’ screen by typing ‘PZDIRVVW’ in the field at the top right corner of the Application tool bar and clicking on the adjoining arrow button.
l Reversal Reference
l Network Code
l Host Code
l Source Code
l Sender Message Identification
l Sender Reversal Identification
The details are shown in following tab details:
l Main
l Processing Details
l R-Transactions
10.1.5.1 ACH Debit Receipts - Reversal View Summary
You can invoke ‘ACH Debit Receipts - Reversal View Summary’ screen by typing ‘PZSIRVVW’ in the field at the top right corner of the Application tool bar and clicking on the adjoining arrow button.
l Reversal Transaction Status
l Network Code
l Activation Date
l Interbank Settlement Amount
l File Reference
l Exception Queue
l Booking Date
l Reversal Account
l Reason Code
l Value Date
l Interbank Settlement Currency
l Debit Amount
