Considerations When Converting a Project to SDEF
P6 Professional projects can store far more data than the SDEF specification requires. For example, the SDEF file structure allows for only one application of a resource per activity, while P6 Professional enables you to apply a resource to an activity repeatedly using assignment lags and durations.
P6 Professional projects intended for use with the SDEF interface should comply with the SDEF specification. There is no requirement to utilize the additional capabilities that P6 Professional offers because the SDEF file structure cannot store the additional data.
The following explains what you should expect and how you should structure your data when exchanging projects between P6 Professional and SDEF formats.
Restrictions Relating to Fields and Data Types
Data mapping
The following table describes how some XER data is converted to SDEF.
SDEF Field
XER Field or Calculation
Total Qty
Planned Units for the activity assignment.
Cost Per Unit
Planned Cost divided by the Planned Units for the activity assignment.
Qty to Date
Actual Units for the activity assignment.
Activity Cost
Planned Cost for the activity assignment.
Cost to Date
Actual Regular Cost for the assignment plus the Stored Material Cost (STMA) amount for the activity.
Note The Stored Material Cost is derived from the Activity UDF named STMA. Refer to Required User-defined Field (STMA) for more information.
Required User-defined Fields
Some data fields required by the SDEF format do not exist in the XER format by default. You must create these fields as user-defined fields (UDFs) in P6 Professional.
When converting an SDEF file to XER, if these fields do not exist as UDFs in the XER project, they will be created automatically during the import process. If the UDFs were previously defined in P6 Professional (to be used for a different purpose), you should rename the pre-existing UDFs before importing an SDEF file.
When converting an XER file to SDEF, if these fields do not exist as UDFs in the XER, the SDEF fields will be blank when you convert the exported XER file to an SDEF file.
UDF Name
Data Type
Description
STMA
Number
The stored material cost data associated with an activity.
Contract Number
Text
The identifying number of the contract.
Note This field cannot be longer than six characters. If any values in this field are longer than six characters, the data will be truncated to the first six characters when you convert to SDEF.
Contractor Name
Text
The name of the contractor.
Note This field cannot be longer than 36 characters.
Required Activity Codes
The US Army Corps of Engineers requires all projects to use a predefined activity code structure. This structure specifies the name and maximum length of each activity code in the project. The SDEF format adheres to this structure; therefore, all P6 Professional projects being exported to SDEF format must have an activity code structure that exactly matches the predefined structure.
The following table shows the required activity code structure:
Code
Max Length
Description
WRKP
3
Workers Per day
RESP
4
Responsibility
AREA
4
Area
MODF
6
MOD or Claim #
BIDI
6
Bid Item
PHAS
2
Phase
CATW
1
Category of work
FOW
30
Feature of work
Note
Last Published Monday, December 8, 2025
