Creating Risk UDFs
Create risk user-defined fields (UDFs) to store additional project risk data on the Risks page that is pertinent to your project or business and is not available from the default fields. For example, you might need to include a location field to identify where the risk might occur, or a ranking field to determine the order in which the risks will be handled.
UDFs can be of many types: text, start date, finish date, cost, number, integer, or indicator. Data from UDFs is not used in scoring calculations.
To create a risk UDF:
  1. Click Administration.
  2. On the Administration navigation bar, click Enterprise Data.
  3. On the Enterprise Data page, expand Risks and click Risk UDFs.
  4. On the Risk UDFs page:
    1. Click  Add.
    2. In the User Defined Field, double-click and type a name.
    3. In the Data Type field, choose a type from the list.
    4. Click Save.
Tip
Related Topics
About User Defined Fields
Working with User Defined Fields
Creating Project UDFs
Defining Formulas for User Defined Fields
Defining Indicators for User Defined Fields
Defining Statements for User Defined Fields
Creating WBS UDFs
Creating Activity UDFs
Creating Expense UDFs
Creating Step UDFs
Creating Issue UDFs
Creating Document UDFs
Creating Assignment UDFs
Creating Resource UDFs
Risk UDFs Page
Last Published Friday, December 19, 2025
