Assigning a Resource Manager Delegate for Timesheets
If you are a resource manager, you can assign a temporary delegate to process timesheets awaiting your approval while you are not able to process them yourself. For example, you might be on business travel or vacation, or the workload requires you to assign timesheet approval responsibility to others.
To assign a resource manager delegate:
  1. Click Approvals.
  2. On the Approvals navigation bar, select Timesheets.
  3. On the Timesheets page:
    1. Select Resource Manager from the Approving as list.
    2. Click Actions  and select Assign Resource Manager Delegate.
  4. In the Assign Resource Manager Delegate dialog box:
    1. Click  Select and select a user from the Select a User dialog box.
    2. To activate the delegate's approval rights, select Make this delegate active.
    3. Click Apply.
Tip
Related Topics
About Timesheets
Working with Timesheets
Configuring Resources for Timesheets
Approving or Rejecting Timesheets
Sending Email about Timesheets to Resources
Assigning a Project Manager Delegate for Timesheets
Timesheets Page
Assign Resource Manager Delegate Dialog Box of the Timesheet Approval Page
Last Published Friday, December 19, 2025
