About Filters
As you work with increasing amounts of data over time, you will recognize a need to limit your focus to only the data most relevant to your particular task or need. A filter is a predefined constraint you place on data so that data that does not meet your filter criteria is hidden and only the data you need are shown.
Last Published Friday, December 19, 2025
