Configuring Compression Settings for P6 EPPM Web Services
To set your compression settings:
  1. Open the Primavera P6 Administrator.
  2. In the Configurations drop-down list, select your configuration.
  3. In the sidebar select Web Services/Compression.
Set the minimum size for response compression. responses smaller than this will not be compressed to gzip format.
Set a value between Between 0 and 2147483647 bytes, the default is 400.
Related Topics
About Configuring P6 EPPM Web Services in the Primavera P6 Administrator
Configuring Authentication Mode for P6 EPPM Web Services
Configuring Username Token Profile Settings for P6 EPPM Web Services
Configuring SAML Token Profile Settings for P6 EPPM Web Services
Configuring Message Protection Settings for P6 EPPM Web Services
Last Published Friday, March 27, 2026
