Configuring Check Schedule in Services Settings
If you are running services and P6 on the same server, you should keep the defaults.
To configure the check schedule settings:
  1. Open the Primavera P6 Administrator.
  2. In the Configurations drop-down list, select your configuration.
  3. In the sidebar expand Services, then expand Publication and select Job Services.
  4. Select Check Schedule.
    1. Select Active Mode if you want jobs processed continuously until all jobs finish. Clear this field if you want each job processed according to the Interval.
    2. In the Interval field, select the amount of time to wait before running the next available job.
      The default value is 10s.
      Enter a value between 1 second and 24 days.
    3. In the Concurrent Threads field, enter the number of processes used for this service on this server. A value of 0 indicates that that this job will not run on this server.
      The default value is 2.
      Enter a value between 0 and 20.
Related Topics
Configuring Job Services in Services Settings
Configuring Scheduler in Services Settings
Configuring Leveler in Services Settings
Configuring Summarizer in Services Settings
Configuring Apply Actuals in Services Settings
Configuring Import/Export
Configuring Unifier in Services Settings
Configuring Overallocation Check in Services Settings
Configuring Global Replace Service in Services Settings
Configuring Sync Units
Configuring CopyProject in Services Settings
Configuring Baseline in Service Settings
Configuring GatewaySynchronization
Configuring Store Period Performance in Services Settings
Configuring Recalculate Assignment Cost in Services Settings
Configuring Rename Document Folder in Services Settings
Configuring CopyWBS in Services Settings
Configuring Export Excel in Services Settings
Configuring Import/Export Enterprise Data in Services Settings
Configuring Generate Reports in Services Settings
Configuring Checkin Enterprise Data in Services Settings
Configuring Checkout Enterprise Data in Services Settings
Configuring Preview Baseline in Services Settings
Configuring Project Check in Services Settings
Last Published Friday, March 27, 2026
