Enabling the Java Security Manager
The Java security manager enables programmers to establish a custom security policy for their Java applications.
Unless you enable the security manager before you start the P6 Integration API server, the security manager is disabled. To enable/disable the security manager, edit the P6 Integration API server's startup script with a text editor and uncomment or comment the appropriate command:
  1. For Windows, edit the startAppServer.cmd file.
    For Linux, edit the startAppServer.sh file.
  2. Uncomment or comment one of the following:
    In Windows:
    SET ENABLE_JAVA_SECURITY_MANAGER=-Djava.security.manager
    Linux:
    Note The P6 Integration API server can use different policy files for different application/web servers.
See Also
P6 Integration API Setup Tasks for On-Premises
Changing Database Configuration Settings for P6 Integration API
Configuring Integration API Server Settings
Configuring P6 Integration API Authentication
Last Published Friday, March 27, 2026
