Configuring Oracle Analytics Publisher in the Primavera P6 Administrator
You must configure Oracle Analytics Publisher settings for Oracle Analytics Publisher to work with P6.
To configure your Oracle Analytics Publisher settings:
  1. Open the Primavera P6 Administrator.
  2. In the Configurations drop-down list, select your configuration.
  3. In the sidebar selectDatabase.
  4. Select your Instance from the drop-down list.
  5. Expand BI Publisher.
    Note Changes to these settings require you to restart the P6 server.
  6. Select Personal Folders, to enable personal folders per user. If you do not want to use personal folders, leave the option clear. Users have their own personal folders where they can store their objects. Only the user who created and saved the content in the folder can access the folder.
  7. In the Server URL field, enter the URL used to connect to the Oracle Analytics Publisher web service to P6.
    For example, http://serverIP:port/xmlpserver/services/PublicReportService?wsdl
  8. In the Folder Paths field, enter the relative path to the Oracle Analytics Publisher P6 reports folder where P6 will search for reports.
    Example format (the forward slash is required):
    /P6REPORTS
  9. In the Version field, enter the version of Oracle Analytics Publisher that you want to integrate with P6.
  10. In the Admin Username field, enter the username for a WebLogic Server Administrator.
  11. In the Password field, enter the password for the WebLogic Server Administrator.
  12. In the Sender Email ID field, enter the email address that you want users to see if they choose to receive reports by email.
Related Topics
About Database Instance Settings
Configuring Driver Class and URL for Database Instance Settings
Configuring User Security for Database Instance Settings
Configuring Connection Pool for Database Instance Settings
Configuring Oracle WebCenter Content Core Capabilities (WCCC) in the Database Instance Settings
Configuring the Oracle Database Content Repository
Configuring CMIS-Compliant Content Repository in the Database Instance Settings
Configuring Session Settings in the Database Instance Settings
Configuring Cost Based Optimization Settings in the Database Instance Settings
Configuring Import/Export Options (Scheduled Service)
Last Published Friday, March 27, 2026
