Configuring Import/Export Options in Services Settings
Primavera P6 Administrator Setup Tasks > About the Configurations Tab in the Primavera P6 Administrator > About the Primavera P6 Administrator Services Settings > Configuring Job Services in Services Settings > Configuring Import/Export
To set your import/export options settings:
- Open the Primavera P6 Administrator.
- In the Configurations drop-down list, select your configuration.
- In the sidebar expand Services, then expand Publication and select Job Services.
- Select Import/Export.
- Under Import/Export Options:
- Select Store Files In Database if you want imported files including images to be stored in the database. Leave this field clear if you do not want files to be stored in the database.
- In the Temporary File Location(ASAP Service) field, enter the location to store the temporary file during the XML import/export process or image storing process. If you do not specify a location, the temporary file is placed in the bootstrap home location, which is in the P6 home directory (for example, c:\p6home).
- In the Maximum file size field, enter the maximum file size (in KB) for XML import and image files.
Note: The JVM settings and available space in the Temporary File Location also affect the maximum file size for import. The maximum file size for export is determined by the JVM settings of your application server and the space available in the Temporary File Location.
The default value is 102400.
Enter a value between 1024 and 2147483647.
Note There are also settings to configure the maximum height and width of stored images in P6 on the Data Limits page of Application Settings.
Related Topics
Configuring Import/Export Service in Services Settings
Last Published Friday, March 27, 2026
