About Configuring P6 EPPM Web Services in the Primavera P6 Administrator
Primavera P6 Administrator Setup Tasks > About the Configurations Tab in the Primavera P6 Administrator
One P6 EPPM Web Services server instance can control more than one database and you can specify an authentication mode for a database through the Authentication Configuration wizard.
You can use the Primavera P6 Administrator to set the authentication mode, token profiles and message protection settings. If you use SAML for P6 EPPM Web Services, you must use Single Sign-On or LDAP authentication for P6 EPPM. You must configure additional settings for LDAP authentication with secure communication (SSL) between the P6 EPPM Web Services server and the LDAP server.
To configure P6 EPPM Web Services and P6 to work together, you must set the P6 EPPM Web Services settings in the Primavera P6 Administrator.
The server can be configured to authenticate user credentials using the following methods:
- Username Token Profile
- Security Assertion Markup Language (SAML) 1.1 or 2.0
- HTTP Cookies (on-premises only)
- OAuth
If you select multiple authentication modes, priority is given in the order of the list above, with Username Token Profile being the highest priority and OAuth being the lowest priority.
Note
- A P6 EPPM Web Services configuration might include database instances that are not set to the same authentication mode as the P6 EPPM Web Services server. If a user connects and requests a database that is set to a different authentication mode than the P6 EPPM Web Services server, an error message displays. The user must select a database that matches the authentication mode set for the P6 EPPM Web Services server.
- For more information on the Primavera P6 Administrator see Primavera P6 Administrator Setup Tasks.
- See the P6 EPPM Web Services Programming Guide for more information about using P6 EPPM Web Services.
Related Topics
Configuring Authentication Mode for P6 EPPM Web Services
Configuring Username Token Profile Settings for P6 EPPM Web Services
Configuring SAML Token Profile Settings for P6 EPPM Web Services
Configuring Message Protection Settings for P6 EPPM Web Services
Last Published Friday, March 27, 2026
