Configuring Browser Settings for Safari
Note Before you begin, ensure you are using the supported version of Safari. See the Tested Configurations document for more information.
- Open Safari.
- From the Settings drop-down, select Preferences.
- In the General dialog box, select Security.
- In the Web Content section:
- Select the following:
- Enable Plug-ins
- Enable Java
- Enable JavaScript
- Deselect Block pop-up windows.
- Select Advanced.
- Select Press Tab to highlight each item on a webpage.
- Close the dialog box.
Tip
Complete the following steps to enable the Java plug-in:
- In the Java section, select Run in Unsafe Mode for the P6 URL.
Related Topics
Configuring Settings on Client Machines
Configuring Browser Settings for Mozilla Firefox
Last Published Friday, March 27, 2026
