Configuring IIS 8.5 for P6 Team Member
To ensure that your instance of P6 Team Member works correctly with IIS 8.5, you will need to update your web.config file; otherwise, you might experience an error when attempting to select an option from the My Tasks drop-down list.
To configure IIS 8.5 for P6 Team Member:
- Navigate to %SystemDrive%
\inetpub\wwwroot. - Open web.config.
- Add
<modules><remove name="WebDAVModule" /></modules>to the inside of the<system.webServer></system.webServer>tag. - Add
<remove name="WebDAV" />beneath the<handlers></handlers>tag, which can be found inside the<system.webServer></system.webServer>tag. - Save the file and the close it.
Related Topics
Creating a New Primavera P6 Administrator Configuration
Configuring P6 Team Member Web Settings
Configuring Email Statusing Service for P6
Last Published Friday, March 27, 2026
