Add a view currency (P6 Professional Only)
  1. Choose Admin, Currencies.
  2. Click Add.
  3. Click the General tab, then type an ID that clearly identifies the currency type.
  4. Type the currency's name.
  5. Enter the symbol used to identify the currency.
  6. Enter the global exchange rate for the currency.
  7. Click the Appearance tab, then select the symbol used to separate whole values from decimal values in the currency display, for example, 500.5 or 500,5.
  8. Select the symbol used to separate groups of digits in the currency display, for example, 300,000 or 300-000.
  9. Select the number of decimal places to display in currency values, for example, none (70), one (70.1), or two (70.14).
  10. Select the format used to display positive and negative currency values.
Last Published Friday, December 12, 2025
