Define maximum ID lengths (P6 Professional Only)
  1. Choose Admin, Admin Preferences.
  2. Click the ID Lengths tab, then specify the number of characters each code may have. Valid values are 1-40.
    Note
    If you change the maximum number of characters in a code length, your change only applies when you add new codes or edit existing codes.
Last Published Tuesday, October 14, 2025
