Rename document categories (P6 Professional Only)
Defining Administrative Categories (P6 Professional Only) > Document Categories (P6 Professional Only)
- Choose Admin, Admin Categories.
- Click the Document Categories tab.
- Double-click the category whose name you want to change, then type the document category's new name.
Tip
To change the order in which document categories are listed, select the document category you want to move, then click Shift Up or Shift Down.
Note
If you change a document category's name, your change applies to all document item assignments.
Last Published Tuesday, October 14, 2025
