Add an If statement
An If statement defines conditions under which certain changes should be made to project data. When the If statement is true, the changes specified in the Then statement are applied. When the If statement is not true, the changes in the Else statement are applied.
- Choose Tools, Global Change.
- Click New, or select an existing specification and click Modify.
- In the topmost section of the Modify Global Change dialog box, select Activities, Activity Resource Assignments, or Project Expenses for Subject Area.
- Type a name to identify the Global change specification.
- For Parameter, select to include All of the Following conditions in the If statement, Any of the Following conditions in the statement, or a data item.
- Select a statement criteria in the Is field.
- Define a value for the specified parameter.
- If necessary, define a high value for the specified parameter.
- To define more than one If statement for this Global change session, click Add and repeat steps 5 through 8.
Last Published Friday, December 12, 2025
