Assign project codes and values
  1. Choose Enterprise, Projects, then select the project to which you want to assign a code and value.
  2. Click the Codes tab.
  3. Click Assign.
  4. Select the project code value you want to assign.
    You can only assign one value per code.
  5. Click the Assign button, then click the Close button.
Tip:
Last Published Thursday, April 3, 2025
