Assign Project Codes dialog box
Use the Assign Project Codes dialog box to assign a project code to the current project.
Display Options bar: Click to change the display.
Search: Type a project code or code description to display a filtered list of project codes whose code or description begins with this value.
Project Code: Lists code values for each project code.
Code Description: Describes each project code value.
Assign: Assigns the selected code to the current project.
Remove: Removes the selected code from the current project.
Last Published Friday, December 12, 2025
