Assign resource codes and values
- Choose Enterprise, Resources, then select the resource to which you want to assign a code and value.
- Click the Codes tab.
- Click Assign.
- Select the resource code value you want to assign.
You can only assign one value per code. - Click Assign, then click Close.
Tip:
- To change a code value assignment, double-click the code value you want to change and select a new code value.
- To remove a resource code, select the code and value you want to remove in the Codes tab, then click Remove.
Last Published Thursday, April 3, 2025
