Assign role codes and values
  1. Choose Enterprise, Roles, then select the role to which you want to assign a code and value.
  2. Click the Codes tab.
  3. Click Assign.
  4. Select the role code value you want to assign.
    You can only assign one value per code.
  5. Click Assign, then click Close.
Tip
Last Published Friday, December 12, 2025
