Assign Resource Codes and Assign Role Codes dialog boxes
Use the Assign Resource Codes dialog box to assign a resource code to the selected resource. Use the Assign Role Codes dialog box to assign a role code to the selected role.
Display Options bar: Click to change the display.
Search: Type a resource code, role code, or code description to display a filtered list of resource codes or role codes whose code or description begins with this value.
Resource Code or Role Code: Lists code values according to resource code or role code. To sort the display, click the Resource Code or Role Code column label.
Code Description: Describes each code value.
Assign: Assigns the selected code to the current resource or role.
Remove: Removes the selected code from the current resource or role.
Last Published Friday, December 12, 2025
