Create a project calendar
- Choose Enterprise, Calendars, then choose Project.
- If more than one project is open, select the projects to which you want to add a calendar, then click Add.
- Select the calendar you want to copy for the new project calendar, then click the Select button.
- Type the new calendar's name.
- Click Modify and edit the new calendar.
Last Published Friday, December 12, 2025
