Customize a Project Table
You can customize an existing Project Table by specifying the font, colors, and row height; filtering the information it includes; specifying how you want the data grouped and sorted; and specifying which data field columns you want to include.
- Display the table, then use the View menu to select the type of information you want to change.
Last Published Thursday, April 3, 2025
