Customize Activity Usage Spreadsheet columns
You can customize the columns that display in the left pane of the Activity Usage Spreadsheet.
  1. Display the spreadsheet, then choose View, Columns.
  2. To add a column to the spreadsheet, select it in the Available Columns section, then click .
  3. To add all available columns to the spreadsheet, click .
  4. To remove a column from the spreadsheet, select it in the Selected Options section, then click .
  5. To remove all current columns from the spreadsheet, click .
    You must select at least one column to display in the spreadsheet.
  6. To change the order in which columns display, in the Selected Options section, select a column you want to move:
    To move the column left, click  .
    To move the column right, click .
  7. To update columns in the spreadsheet, click OK, or to view your changes without closing this dialog box, click Apply.
    To restore the default columns, click Default.
Related Topics
Select Activity Usage Spreadsheet fields
Display the Activity Usage Spreadsheet
Last Published Friday, December 12, 2025
