Delete a threshold
- Choose Project, Thresholds.
- Select the threshold, then choose Edit, Delete.
- Click Yes.
Note
If you delete a threshold, historical issue data are also deleted. If you disable a threshold, new issues are not generated for it, but historical issue data are maintained.
Last Published Friday, December 12, 2025
