Delete an EPS node or project
  1. Choose Enterprise, Projects, then select the EPS node or project that you want to delete. Choose Edit, Delete.
  2. Click Yes to confirm.
Tip
When you delete an EPS node, all projects in that branch of the hierarchy are also removed. To save projects in a branch before deleting it, first copy and paste those projects to another area of the hierarchy.
Related Topics
EPS node
Last Published Friday, December 12, 2025
