Delete menus and menu commands
You can delete a command from any menu, and you can delete menus. To delete a menu or menu command:
- Choose View, Toolbars, Customize.
Opening the Customize dialog box switches the menus into Edit mode, which enables you to delete commands and menus. You do not need to use the Customize dialog to delete commands and menus; however, you must leave the dialog open to enable you to delete commands and menus. - To delete a menu, right-click the menu label, then choose Delete.
To delete a command, click the menu label that contains the command you want to delete, then right-click the command and choose Delete.
Tip
When you delete a menu or command, it is no longer available for display. To recover deleted menus and commands, you must revert to the default settings for all toolbars and menus.
Related Topics
Reset toolbars and menus to factory defaults
Last Published Friday, December 12, 2025
