Edit EPS-level activity code values
  1. Choose Enterprise, Activity Codes.
  2. Choose EPS.
  3. Select the code whose value you want to change.
  4. To change a value or description, double-click the item you want to change, then type the new text.
    To change the placement of the code in the list, click the appropriate arrow.
  5. Click Close.
Tip
If you change an activity code value, your changes apply to all activity assignments.
Last Published Friday, December 12, 2025
