Edit EPS-level activity codes
  1. Choose Enterprise, Activity Codes.
  2. Choose EPS, then click Modify.
  3. Select the activity code you want to edit.
    To change the code's name, type a new name.
    To change the maximum number of characters the code's values may have, specify a new number.
    To change the placement of the code in the list, click Shift Up or Shift Down.
  4. Click Close.
Tip
Last Published Friday, December 12, 2025
