Edit past period actual data
You can view and edit past period actual data for any financial period in the Activity Table and the Resources tab of Activity Details. The available financial period columns are listed in the Financial Period Value group of columns in the Columns dialog box.
You can display Activity Table columns for all of the following financial period fields:
You can change the Resources tab columns of Activity Details to display Actual Cost and Actual Units columns for any financial period.
After you expose the columns you want, you can edit any value by clicking in the field.
Tip
Note
When connected to a P6 EPPM database: You must be assigned the appropriate project privileges as defined in P6 to edit past period actual data.
Related Topics
Change Resources tab columns
Define Activity Table columns
Last Published Friday, December 12, 2025
