Edit project code values
- Choose Enterprise, Project Codes.
- Select the project code whose value you want to change.
- To change a value or description, double-click the item you want to change, then type the new text.
Tip
If you change a project code value, your changes apply to all project assignments.
Related Topics
Last Published Friday, December 12, 2025
