Edit role code values
- Choose Enterprise, Role Codes.
- Select the role code whose value you want to change.
- To change a value or description, double-click the item you want to change, then type the new text.
Tip
If you change a role code value, your changes apply to all role assignments.
Related Topics
Last Published Friday, December 12, 2025
