Enterprise Project Structure overview
The Enterprise Project Structure (EPS) forms the hierarchical structure of your database of projects. Each EPS node (or folder) can be subdivided into multiple levels to represent the work that needs to be done in your organization. The number of levels and their structure depend on the scope of your projects and how you want to summarize data.
You can use the EPS to
All projects in the enterprise exist within the EPS hierarchy, a graphical representation of your project structure.
When P6 Professional is connected a P6 EPPM database you can define the EPS using either P6 Professional or P6.
The levels and structure of your company's EPS depends on the scope of your projects and how you want to summarize data. You can define one or multiple root nodes, up to 50 combined WBS/EPS levels and as many projects as necessary to complete the required work set forth by the operations executive and project managers in your organization.
Before you begin defining your company's EPS, you should become familiar with the structures and procedures established for your enterprise, such as codes, calendars, and other company-wide standards. Once the EPS hierarchy is defined, you can begin to develop projects by adding information, activities, and resources.
Related Topics
EPS node
Last Published Friday, December 12, 2025
