Funding Sources dialog box
Use the Funding Sources dialog box to set up a funding sources dictionary containing any non-profit, government-allocated, or other funding sources for easy assignment to budget items.
Display Options bar: Click to customize the Funding Sources hierarchy. You can display or hide funding source details, view information in a table or chart format, and change colors or fonts for information in the table or chart.
Funding Source: Lists all available funding sources.
Funding Source Name: Lists the selected funding source.
Funding Source Description: A description of the selected funding source. You can only view the description in this field; to add or edit a description, you must use the HTML editor.
Modify: Click to add or edit the description for the selected funding source in an HTML editor. In the editor, you can format text, insert pictures and tables, copy and paste information from other document files (while retaining formatting), and add hyperlinks.
Copy: Click to copy the selected text. After copying text, you can paste it into the HTML editor or into another application.
Print: Click to print the displayed description.
Add: Adds a funding source.
Del. / Merge: Deletes the selected funding source.
Cut: Removes the selected element from the funding source hierarchy. To reinsert the element in a new location, select a new position, and click Paste.
Copy: Copies the selected element. You can select a different position in the hierarchy and click Paste.
Paste: Pastes a funding source element that you have either copied or cut.
Arrows: Change the selected element's position in the hierarchy.
Last Published Friday, December 12, 2025
